Tag all makes a mess in my sheet
m.pedronA2WSS
Observer Observer
m.pedronA2WSS
Observer
Observer
Is there a way to fasten my work with ''tagg all''
When i use this it makes a insanly mass in my sheet,
Is there a way that i can tag all a complete sheet with pipes etc.. without the tags overlap each other and make a mess like this,
also tagg all function will tag every single pipe, also the ones that are 10cm long, is there a way it will only tagg pipes that are 50cm long instead of ''every'' single one.
this will speed things up alot and i dont have to tagg all pipes in each room for 100 apartments.
Thanks alot.
pendean
Community Legend
Community Legend
Which software are you using? You opted to post in a forum that is likely to never get you a solution.
m.pedronA2WSS
Observer
Observer
i use revit 2022 for this project
pendean
Community Legend
Community Legend
All the REVIT user support forums are over here
https://forums.autodesk.com/t5/revit-products/ct-p/2003
HTH
m.pedronA2WSS
Observer
Observer
oke, thanks
