Hello! I am new to Tandem and I was trying to do a test by creating following the demo from the following repository :
https://github.com/autodesk-tandem/stream-data-simulator?tab=readme-ov-file
and I am seeing in the terminal after running the "npm start" , screenshot 1 that says "
> stream-data-simulator@1.0.0 start
> node src/main.js
sendDataToStream
number of updated streams: 2
sendDataToStream"
However I still can't configure and map my temperature values to the steam connection , I am supposed to see configure connection to do mapping but instead I see " No parameters found for current classification Use a classification with parameters"
I am sure I doing something wrong or I am missing a step but not sure what is it ?
Thank you for your help
Solved by jan.liska. Go to Solution.
Hello, you need to apply classification to the stream and then configure parameters for stream using Configure connections command in Tandem. This command allows you to map values which are send to Tandem against parameters from classification.
