Potential heatmap bug - Unused Connections
Chad-Smith
Chad-Smith
I think I may have found a minor heatmap bug.
My facility has a variety of climate sensors. I added a new climate sensor the other day and quickly noticed that the new sensor wasn't calibrated the same as the other sensors. It was off by approximately 1 degree C and therefore was producing biased heatmap results.
So, I decided to remove that problematic sensor's relationships from its Host and Rooms, but left its Connection in place and its assigned Classification.
What I found was that even though that sensor no longer had any presence in the model, its streamed values still influenced the Heatmap Settings. In my case, this sensor that was producing a 1 degree C higher temperature than it should have, which then determined the default Heatmap Settings Max value. This in turn impacted the heatmap colour scale.
To work around this, I had to remove the Classification from the sensor's Connection. BTW, I want to leave this Connection in place while I replace the physical sensor, then I will set its relationship to the model again.
I feel that there is a bug in which active Connections with Classifications that don't have any relationships with the model are affecting model-based analysis. I'm not sure if this is as-designed, but it doesn't feel right.
As a side idea request here, maybe it might be good to have an Enable/Disable option for Connections?
jessica_smith
Hi @Chad-Smith ,
Couple questions:
  1. How are you sending the data in Tandem? Based on your previous post, I'm assuming you're utilizing Tandem Connect?
  2. What type of device(s) are you using?
The enable/disable enhancement is interesting. What additional benefits do you see this bringing to the user? Any particular use cases come to mind?
Thanks!
Jessica Smith
Content Marketing Specialist, Autodesk Tandem
Autodesk Tandem | Subscribe Now! | Autodesk Tandem Resources
Chad-Smith
Hi Jessica.
  1. Data is currently being sent via an edge server. I haven't yet had the chance to venture into Connect.
  2. The devices are IoT sensors.
My thoughts on the disable/enable of Connections is more to do with replacing devices/equipment. If there is a defective item, the question is do we want knowingly incorrect data to continue to be streamed in Tandem?
But, I come back to my original question of why that Connection is still streaming data to a heatmap if its relationships were removed? Having a Connection disable/enable feature may not be required is severing its relationships did the same thing.
Or is my understanding not quite right here? Does a Connection's Classification have other model impacts beyond the relationships?
jessica_smith
Hi @Chad-Smith ,
I should have been more specific with my question. What make and model are the IoT devices?
As for the disable/enable button, my thoughts are that if users were to replace an IoT device, they could want to keep the historical data. As the product is designed today, this could be done in two ways;
  1. When the replacement IoT device is set up, the existing Connection would be updated in Tandem to receive data from the new device. Then, the historical data from the retired device would be there and data from the new device would appear as well. I talk about updating existing Connections in the Connections Highlight – Batch Create-Update-Modify Connections forum post.
  2. When a replacement IoT device is set up, users create a new Connection in Tandem for the new device. When the retired device stops sending data, Tandem shows an offline status for that device until the Connection either receives data again or is removed from the Connections list.
So I'm not sure how much value having the enable/disable button would bring with our current functionality; that isn't to say, though, that over time, it doesn't become necessary.
Does that answer your question?
Jessica Smith
