I need help-Mapping parameters in Autodesk Tandem REC Sample Facility Template
lakhans8857
lakhans8857
Hi all,
I'm new to Autodesk Tandem and still learning and exploring it. I've a query - If I select the REC Sample Facility Template, under the Assets tab -> Parameters -> Streams, the Temperature & Humidity parameters are not mapped. Similarly, for the VAV Boxes -> Air Flow (CFM) parameter, it is also not mapped.
How do I need to connect these parameters with my facility asset? What should I do to map them correctly?
Thanks in advance for your help.
jessica_smith
Hi @lakhans8857 !
Welcome to the world of Autodesk Tandem! Thanks for posting. I recommend checking out a couple of resources.
  • Connections section, on Autdoesk Knowledge Network - This will provide a good overview of the Connections and Streams feature.
  • Tandem's Insider Lounge - This is our beta community. Once you join, you can see and choose which beta features you'd like to test out. Since you are trying to connect physical assets to a twin, I recommend joining the Tande Connect beta. Tandem Connect is a low-code option for sending data from various IoT sources to Tandem. We're always looking for new testers and hearing their feedback.
After you have reviewed these resources, if you still have questions or get stuck, feel free to post here. If you join the beta community and Tandem Connect, please post beta-related questions to the Insider Lounge.
I hope that helps. Let us know if you have any feedback!
Jessica Smith
Content Marketing Specialist, Autodesk Tandem
Autodesk Tandem | Subscribe Now! | Autodesk Tandem Resources
