Model disappearing when zooming in
m.hoper9DMVY
Message 1 of 9
m.hoper9DMVY
Has anyone else experienced an issue with zooming in for certain models? Hopefully you can see the attached video, where I have selected a single model within the facility, but as soon as I zoom in with the mouse the model disappears, and unable to get it back into focus.
If I select other models within this facility, I can zoom and navigate around without any issues
Replies (8)
Message 2 of 9
jessica_smith
HI @m.hoper9DMVY ,
I'm looking into this more. Can you confirm that all the models you have uploaded are revit? There are two that are cut-off in the video.
Thanks!
Jessica Smith
Content Marketing Specialist, Autodesk Tandem
Autodesk Tandem | Subscribe Now! | Autodesk Tandem Resources
Message 3 of 9
iriacarreira
HI @m.hoper9DMVY ,
The instances in which I've encountered a model disappearing in the viewer are usually related to the cut-off planes. There is a limitation in the viewer concerning the distance of an object. In other words, if something is drawn too far from the main model, it can alter the cut-off plane and begin to stop displaying 3D information. Navisworks has a similar issue: Link to article
Whenever I've faced this issue, I've opened the model in question in the authoring tool to check for any odd geometry modeled far from the main model. I would then delete it, re-upload, and this typically resolves the problem. I've encountered this issue more frequently with fab models or dwg fab models.
I'm not sure if this is the issue you're facing, but I would recommend starting there.
Iria Carreira
Senior Product Manager, Autodesk Tandem
Message 4 of 9
m.hoper9DMVY
Hi Jessica - They are all Revit file
Message 5 of 9
m.hoper9DMVY
Thanks Iria - I did have a look at this previously, but I will have a look again to see if I missed anything
Message 6 of 9
m.hoper9DMVY
Hi Iria - Thanks for this, I don't believe there are any objects too far away from the main model after checking again. I am still investigating other ideas based on some online forums responses
Message 7 of 9
m.hoper9DMVY
Done some further investigation into this, and turns out it was the sub-category "Centre Lines" within category MEP Fabrication Pipework which was causing this issues. I have a support call open to initially look at why it doesn't show anything in the 3D view on ACC Docs when this sub-category is turned on
Message 8 of 9
iriacarreira
So when filtering out the Centre Lines from the viewer the zoom works as expected?
Iria Carreira
Message 9 of 9
m.hoper9DMVY
I'm actually having to hide these in Revit before uploading to Docs then Tandem, as it is a subcategory which is causing the error by the looks of it.
But yes once I turn off this subcategory in Revit and upload, the viewing within Tandem works as expected
