I want to open .xyz files, do you know how can i do that, with which of Autodesk products i can do that?
Solved by alexpizarrogalvis87. Go to Solution.
CIVIL 3D
CIVIL 3D
you tried it and sure of it?
any software from Product Design & Manufacturing softwares?
Firstly, which software do you want to open it in..? There are a few Softwares which can. So..
And does it contain only the X,Y,Z co-ordinates..? Can you specify..?
@georgeemad , I think AutoCAD, AutoCAD Map 3D, Fusion,Revit might be able to open .xyz Files..
Have a Look at this GOOGLE Result for more..
the Files contains a 3d model of trees logs, the file extensions are .XYZ and .nmx and .CFG
I wish to open them then use them in both Excel files and python to use them in artificial intelligence.
i Tried fusion but i did not work, maybe i do not know how to do it, can you help? should i change the file extensions to match of fusion 360?
Here's what I've found: a few Autodesk programs (including AutoCAD Map 3D) use can use .xyz files, but they have to be converted to .txt files.
Hope that helps!
Hope that helps!
Frankly Speaking, I heard .xyz File for the First Time here.. 😁.
But I'll try to help you as far as possible.
So in which Software/App did you create the .xyz File..?
MillExpert, it us a milling big machine, and the files are created by their program
how to convert the files ?
