Student Room
Welcome to the Autodesk Student Room. Join us to learn about the latest industry trends, connect with other members, showcase your work, and more.
.XYZ Files
12 REPLIES 12
Message 1 of 13
georgeemad
390 Views, 12 Replies
.XYZ Files
georgeemad
I want to open .xyz files, do you know how can i do that, with which of Autodesk products i can do that?
.XYZ Files
12 REPLIES 12
Message 2 of 13
alexpizarrogalvis87
CIVIL 3D
CIVIL 3D
Message 3 of 13
georgeemad
you tried it and sure of it?
Message 4 of 13
georgeemad
any software from Product Design & Manufacturing softwares?
Message 5 of 13
Firstly, which software do you want to open it in..? There are a few Softwares which can. So..
And does it contain only the X,Y,Z co-ordinates..?  Can you specify..?
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Thanks and Regards,
Rushabh Thakkar.
Message 6 of 13
rushabhthakkar_910
@georgeemad , I think AutoCAD, AutoCAD Map 3D, Fusion,Revit might be able to open .xyz Files..
Have a Look at this GOOGLE Result for more..
Thanks and Regards,
Rushabh Thakkar.
Thanks and Regards,
Rushabh Thakkar.
Message 7 of 13
georgeemad
the Files contains a 3d model of trees logs, the file extensions are .XYZ and .nmx and .CFG
I wish to open them then use them in both Excel files and python to use them in artificial intelligence.
Message 8 of 13
georgeemad
i Tried fusion but i did not work, maybe i do not know how to do it, can you help? should i change the file extensions to match of fusion 360?
Message 9 of 13
dfuller16
in reply to: georgeemad
dfuller16
Here's what I've found: a few Autodesk programs (including AutoCAD Map 3D) use can use .xyz files, but they have to be converted to .txt files.
Hope that helps!
Hope that helps!
Message 10 of 13
dfuller16
dfuller16
It would help to know what you are using these files for.
Message 11 of 13
rushabhthakkar_910
Frankly Speaking, I heard .xyz File for the First Time here.. 😁
But I'll try to help you as far as possible.
So in which Software/App did you create the .xyz File..?
Thanks and Regards,
Rushabh Thakkar.
Thanks and Regards,
Rushabh Thakkar.
Message 12 of 13
georgeemad
MillExpert, it us a milling big machine, and the files are created by their program
Message 13 of 13
georgeemad
in reply to: dfuller16
georgeemad
how to convert the files ?
