Hello friends!
@leowarren34 - @LeoWarren-SGH believe you can help me to solve this last minute problem!
A few minutes ago my academic license was compromised with the expiration period.
I have already submitted the teacher ID of my educational institution and I believe there will not be enough time for it to be approved.
Because tomorrow I have to teach a mentorship for a challenge proposed by SENAI-DF here in Brazil you can view the event website here - http://www.portaldaindustria.com.br/senai/canais/grand-prix-de-inovacao/#programacao
I have a few hours to adjust the material for my presentation using Fusion 360 and its tools for students participating in the Online Challenge.
Please I would like someone to help me to solve this last minute problem!
Thank you for your attention to this request!
I look forward to it, thank you!
Solved by amanda.k. Go to Solution.
Solved by leowarren34. Go to Solution.
Hi @lucasliraAU,
If you went through SheerID it's usually instant to 20 mins. If your ID ticks all of the boxes of having your name, name of the institution and expiry date then it should get approved quickly. If it gets rejected then it can take longer to come back but I've had it back within an hour.
Plan B would be to try getting a trial license of Fusion 360 which should cover you for the time you need.
For future reference, you can renew your Edu access up to 30 days before it expires so you don't have to let your license lapse.
I'll also reach out to the team to see if they can do anything.
@lucasliraAU On it, give me a few so I can escalate. Thanks to @leowarren34 for directing alerting me on this one, I wasn't checking. Will update you on this thread when I hear!
Hello team!
I would like to thank you for your immediate contact and your efforts to help me solve this problem that has appeared in the last few minutes, I have already sent the photos of my teacher card at the institution I am currently at.
I await an update so that I can proceed with my activities to meet some young people from the GP-SENAI challenge.
Regards, Thank you @amanda.k @leowarren34
Hello again team!
I have already received the guidelines by email academico!
The information has already been redirected!
Thanks for your attention and support for this case!
Thank you very much - @leowarren34 , @leowarren34
@lucasliraAU - whew! Glad to help. 🙂 Great luck on your challenge tomorrow! Let us know how it goes!
Hello @lucasliraAU !
I arrived late, @leowarren34 and @amanda.k do not play on duty but I want to register that after the Virtual Assistant, this was practically automatic, in some cases it was taking up to 14 days to release.
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão Aceitar Solução.
Rui Raoli
Eng. Civil Esp. em Design de Interiores e Iluminação | Gerente BIM
Of course it will be a pleasure! 😊
I've already shared the material that I'm going to use in a few minutes.
It's a shame the content is all in PT-BR - https://gallery.autodesk.com/projects/164022/gpsenai---documentacao-de-produto---introducao-design-f...
There are some other files that are in .PDF only appear when downloading 🙂
As soon as I have new information I will share it with you here!
