Structural Bridge Design Forum
Welcome to Autodesk’s Structural Bridge Design Forums. Share your knowledge, ask questions, and explore popular Structural Bridge Design topics.
Shear force calculations in Autodesk Structural Bridge Design 2022 using section design
7 REPLIES 7
Message 1 of 8
md01134
1036 Views, 7 Replies
@dave_geeves
Hi Dave,
Could you help out please.
I'm using Autodesk Structural Bridge Design 2022. I'm using the section design to get the Vrd,c for a 1000mm wide x 250mm deep section with B12's at 150mm c/c FF + NF, but every time I try and get an answer, the warning message comes up: "Invalid floating point operation". When I use the 2019 version it will give me the answer of approx. 111 kN.
Have you ever come across this before?
Thanks very much.
Michael.
7 REPLIES 7
Message 2 of 8
dave_geeves
in reply to: md01134
I don't think I have come across this before.  If you zip up your data file and attach it to a reply I will take a look.  It will probably have to be tomorrow afternoon now as I am tied up with another project.
Dave Geeves
Message 3 of 8
md01134
in reply to: dave_geeves
Hi Dave,
Please find attached.
Thanks for the help.
Michael.
Message 4 of 8
dave_geeves
Hi Michael,
Sorry for the delay in responding to this.  I  get exactly the same as you, even if I start a section from scratch.  I have tried changing various parameters to narrow down the cause but the error persists.  I can only hope that the development team have noticed this and will respond accordingly.  I will keep trying but I don't hold out much hope.  I also notice that the section analysis works fine when I create it in 2020 version but if I then load this in to 2022 I then get the failure for the shear calculations.
Sorry I can't help any further.
Kind regards
Dave Geeves
Message 5 of 8
karoly_tarcsi
Hi Michael,
Thanks for contacting us and drawing our attention to this problem.
We added the issue to our shortlist with the highest priority.
Karoly
Karoly Tarcsi
Software Development
Message 6 of 8
simon_hooper
This is fixed by the update named 2022.1.1 Hotfix release (13 Jan 22) available via
manage.autodesk.com/cep/#products-services/updates
Simon Hooper
Message 7 of 8
van.lian
in reply to: simon_hooper
Where is this Hot Fix? I can't find them in the provided link.
Message 8 of 8
simon_hooper
in reply to: van.lian
Try https://manage.autodesk.com/products/updates
Simon Hooper
