Moment value in the Determination of longitudinal strain
I was examining the results for the Determination of longitudinal strain εx calculation and noticed the Factored moment does not match the applied moment in the beam. In the example below, the Factored moment result = 1016 kNm.
However, when you look at the applied load case, it shows a moment of
Would someone know how SBD calculates this moment? or am I missing something?
dave_geeves
By means of trial and elimination I assume you are using AS5100 2017 Amd 1 standards (as opposed to Eurocode, AASHTO or British) and that you are carrying out shear calculations for  a "design section" of a prestressed beam.
If this is the case, then I believe you problem is that on the analysis form you are selection both the load case and setting the "Capacity" to Mx (or other moment direction) so that the factored moment will be the capacity of the section rather than just the applied moment in your load case.
For the shear calculations to be fully meaningful it is important to set both the shear force and the associated moment in the load case and set the capacity to "*Not Used*" so that any shear reinforcement requirements are determined correctly.
Shear Analysis FormShear Analysis Form
I hope this has helped and has successfully answered your question, but if not, then please reply with a zipped up data file attached and a little more explanation.
Please mark my reply as a solution if it has solved your question so that others may benefit by searching for solutions.  Thanks
Kind regards
Dave Geeves
Thank you Dave! That worked.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
