Greetings,
I am designing a pier cross section using Eurocode, I have inputs all the loads and the reinforcement. When I analyze the cross section design, it shows failed to converge. However, when I switch to British code, under the same loading and configuration, the cross section can be converged.
After I switched to British code, I switch back to Eurocode again and the cross section can be converged. Thus, may I know why is there a discrepancy between the cross section converge between Eurocode and British Code. Thank you in advanced for your prompt reply.
Attached 2 files for your reference. The file named "Pier (Autodesk - 2)" cannot be converged while the file named "Pier (Autodesk)" can be converged after switching to BS and switch back to Eurocode.
