How to create a new section?
Message 1 of 16
Dear all,
I am a newbie here. I would like to ask you how to create a new section or how to insert a new section from Autocad. ( for exe the atttached image).
Is that possible in ASBD?
Replies (15)
Message 2 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may find this article helpful.
In ASDB 2016 and 2017 the option is available under the Right Mouse Button
Artur Kosakowski
Message 3 of 16
Thanks for your response .
 I tried to follow your suggestion but there is an error. Please see the attached image.
Give me the solution to fix it pls.
Message 4 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
When exactly does this happen? When you select the Import option or when you opening the dwg/dxf file?
Artur Kosakowski
Message 5 of 16
When I select the insert option
Message 6 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Just to make sure I understand what you mean by Insert correctly. Do you mean that you were able to indicate the dxf/dwg file or this happened when you tried to open the dialog to select this file?
Artur Kosakowski
Message 7 of 16
Thank you a lot
I just fixed it.
Message 8 of 16
Helle ,
I saw  that the post-tensioned concrete is not available in ASBD when using Eurocode+ French Annexe?
Message 9 of 16
Hello
You are right, apparently post tension is available only for British Standards, and for EN codes you can use pre-tension only.
We all hope colleagues from Autodesk will add it soon.
Message 10 of 16
Thanks for your reply,
I am facing a problem
When  defining a beam componant, I used a PC import,  a new section (01. Image) that I created.
An error is non-joining section component. It is why the section is breaked (02. Image)
Please tell me how to fix it.
Message 11 of 16
david.geeves
The problem you are experiencing is because the section used to describe the precast beam section in the  prestressed beam module needs to be a single section component rather than a rectangular section with several voids.
It is quite easy to do this but it is easier for me to show you.  I will put together a short video this afternoon and post it here.
Kind regards
David Geeves
Enterprise Prority Support
Message 12 of 16
david.geeves
Here is the video I promised earlier.
Hopefully this explains things a little more clearly.  The reinforcement and tendons need to be inserted in the standard way
Please mark this post as a solution if it provides the answers you want.
Kind regards
David Geeves
Message 13 of 16
Thanks for this video. Can we have some videos on how to model a steel plate deck ( like a canal ). Thanks.
Message 14 of 16
Good morning,
how did you fix it please? I got the same error.
Message 15 of 16
Philip.Lee
@Anonymous wrote:
Good morning,
What error do you get and when do you get it? Is it when importing a DXF or DWG? If so, can you attach the file to the forum so I can look at it here?
Message 16 of 16
Good morning,
it was because I was using different versions. Thanks anyway!
