Structural Bridge Design Forum
Welcome to Autodesk’s Structural Bridge Design Forums. Share your knowledge, ask questions, and explore popular Structural Bridge Design topics.
Error Zero width in continuous slab
6 REPLIES 6
735 Views, 6 Replies
Hi
Although I a signed a ''Continuous Slab Properties'' with a thickness, I am still having issue with an Error ''Zero width in continuous slab'' see attached screenshots.
The geometry been created in AutoCAD2014 and imported to Structural Bridge Design.
Best Regards
Said
6 REPLIES 6
simon_hooper
Hi Said
I suggest you send your model to Autodesk Support so they can take a look at the problem.
Simon
Simon Hooper
Software Development
in reply to: simon_hooper
Hi Simon
Would you send me an email, I tried to attached it but it wont upload.
BR Said
simon_hooper
You have to zip before upload. I suggest you send to support though.
Simon Hooper
Hi Simon
I have attached the zip file.
Best regards
Dear Simon
I assigned properties as ''Continuous Slab Properties'' for the bridge deck. Where I divided them in 4 meshes. Trying to find which mesh have the issue with assigning section properties. As you can see from the screenshots only one mesh shows the slap thickness in 3D, although I assigned for all meshes with the same section properties.
The attached file is the latest and I used version 2017 of ASBD.
Best Regards
Said
simon_hooper
Hi Said
Go to the 'Sub Model Members' form for the 2D Sub Model.  Shift select members 1 to 18 and delete.  This should sort the issue.  You had overlapping beam elements which was upsetting the continuous slab assignments.
Simon
p.s. in the future I suggest you go through support channel for these types of issues.
Simon Hooper
