Hi
Although I a signed a ''Continuous Slab Properties'' with a thickness, I am still having issue with an Error ''Zero width in continuous slab'' see attached screenshots.
The geometry been created in AutoCAD2014 and imported to Structural Bridge Design.
Best Regards
Said
Solved by simon_hooper. Go to Solution.
Hi Said
I suggest you send your model to Autodesk Support so they can take a look at the problem.
Simon
Hi Simon
Would you send me an email, I tried to attached it but it wont upload.
BR Said
Dear Simon
I assigned properties as ''Continuous Slab Properties'' for the bridge deck. Where I divided them in 4 meshes. Trying to find which mesh have the issue with assigning section properties. As you can see from the screenshots only one mesh shows the slap thickness in 3D, although I assigned for all meshes with the same section properties.
The attached file is the latest and I used version 2017 of ASBD.
Best Regards
Said
Hi Said
Go to the 'Sub Model Members' form for the 2D Sub Model. Shift select members 1 to 18 and delete. This should sort the issue. You had overlapping beam elements which was upsetting the continuous slab assignments.
Simon
p.s. in the future I suggest you go through support channel for these types of issues.
