Stingray Forum (Read Only)
Welcome to Autodesk’s Stingray Forums. Share your knowledge, ask questions, and explore popular Stingray topics.
VR Vive Controller Teleport not working
0 REPLIES 0
Message 1 of 1
384 Views, 0 Replies
I'm new to Stingray/Interactive and have very little knowledge of the gaming industry and so am really getting used to using lua script and the flow editiors. I've recently come across an issue where the teleport on the vive controllers has stopped working when I'm testing the project, the only thing I have changed in the project other than materials that i think would affect anything is the particle effects editor. I was following the youtube tutorial on this subject and was messing about with the particle flow trying to add an emissive setting, which took a few tries, and may have inadvertently changed something I wasn't supposed to and caused an error. I've been cross comparing all the lua script and flow editor for the controllers with the standard vive template but I can't see any noticeable differences.
When in test mode in VR I can see the controllers but only the teleport sound effect works and theres no teleport arc visible. Everything else works fine you just can't move anywhere.
if you could help me out in any way that would be great, i can send you files if that would help to see the errors as well. Apologies for my novice knowledge but it's taking me a while to come to grips with all the coding, especially as there's not much that explains the fundamentals of lua scripting etc online.
Joel
Tags (3)
0 REPLIES 0
