Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Stingray Forum (Read Only)
Welcome to Autodesk’s Stingray Forums. Share your knowledge, ask questions, and explore popular Stingray topics.
Error Compiling When Baking Probes
3 REPLIES 3
906 Views, 3 Replies
Hi there,
I am trying to bake the reflection probes in my scene, but I keep getting an error when it finishes and nothing happens.
'Error Compiling: content/levels/basic-cubemaps/reflection_probe_radiance_bake.texture'
Also when I run the test levels I get the following errors in the log console.
Data / Compiler: Start compiling `6bdbe6d5`
Data / Compiler: Error compiling content/levels/basic-cubemaps/reflection_probe6_radiance_bake.texture
Failure while parsing content/levels/basic-cubemaps/reflection_probe6_radiance_bake.texture:
content/levels/basic-cubemaps/reflection_probe6_radiance_bake.texture(3:13): No input texture file exists for: content/levels/basic-cubemaps/reflection_probe6_radiance_bake, supported extensions: `raw, dds, png, tga, jpg, tif, tiff, jpeg`
Data / Compiler: Error compiling content/levels/basic-cubemaps/reflection_probe_diffuse_bake.texture
Failure while parsing content/levels/basic-cubemaps/reflection_probe_diffuse_bake.texture:
content/levels/basic-cubemaps/reflection_probe_diffuse_bake.texture(3:13): No input texture file exists for: content/levels/basic-cubemaps/reflection_probe_diffuse_bake, supported extensions: `raw, dds, png, tga, jpg, tif, tiff, jpeg`
Data / Compiler: Error compiling content/levels/basic-cubemaps/reflection_probe_radiance_bake.texture
Failure while parsing content/levels/basic-cubemaps/reflection_probe_radiance_bake.texture:
content/levels/basic-cubemaps/reflection_probe_radiance_bake.texture(3:13): No input texture file exists for: content/levels/basic-cubemaps/reflection_probe_radiance_bake, supported extensions: `raw, dds, png, tga, jpg, tif, tiff, jpeg`
Data / Compiler: Error compiling content/levels/basic-cubemaps/reflection_probe_specular_bake.texture
Failure while parsing content/levels/basic-cubemaps/reflection_probe_specular_bake.texture:
content/levels/basic-cubemaps/reflection_probe_specular_bake.texture(3:13): No input texture file exists for: content/levels/basic-cubemaps/reflection_probe_specular_bake, supported extensions: `raw, dds, png, tga, jpg, tif, tiff, jpeg`
Editor / General: Error compiling content/levels/basic-cubemaps/reflection_probe6_radiance_bake.texture
Data / Compiler: Finished compiling `6bdbe6d5` in 0.18 seconds
Test Engine / ResourcePackage: Failed loading texture named `3310de1ad88f2aef`
Test Engine / ResourcePackage: Failed loading texture named content/levels/basic-cubemaps/reflection_probe1_specular_bake
Test Engine / ResourcePackage: Failed loading texture named `e1db2b89820e3126`
Test Engine / ResourcePackage: Failed loading texture named content/levels/basic-cubemaps/reflection_probe2_specular_bake
Test Engine / ResourcePackage: Failed loading material named content/levels/basic-cubemaps/reflection_probe4_bake
Test Engine / ResourcePackage: Failed loading material named content/levels/basic-cubemaps/reflection_probe1_bake
Test Engine / ResourcePackage: Failed loading material named content/levels/basic-cubemaps/reflection_probe2_bake
Test Engine / Steam: Steam systems will be disabled.
Test Engine / Lua: Waiting for test level initialization...
Test Engine / ResourcePackage: Failed loading resource in package `__level_editor_test`, type `texture`, name `3310de1ad88f2aef`
Test Engine / ResourcePackage: Failed loading resource in package `__level_editor_test`, type `texture`, name content/levels/basic-cubemaps/reflection_probe1_specular_bake
Test Engine / ResourcePackage: Failed loading resource in package `__level_editor_test`, type `texture`, name content/levels/basic-cubemaps/reflection_probe2_specular_bake
Test Engine / ResourcePackage: Failed loading resource in package `__level_editor_test`, type `material`, name content/levels/basic-cubemaps/reflection_probe4_bake
Test Engine / ResourcePackage: Failed loading resource in package `__level_editor_test`, type `material`, name content/levels/basic-cubemaps/reflection_probe1_bake
Test Engine / ResourcePackage: Failed loading resource in package `__level_editor_test`, type `material`, name content/levels/basic-cubemaps/reflection_probe2_bake
Test Engine / Unit: Cannot retrieve material resource: content/levels/basic-cubemaps/reflection_probe1_bake to bind to light
Test Engine / Unit: Cannot retrieve material resource: content/levels/basic-cubemaps/reflection_probe2_bake to bind to light
Test Engine / Unit: Cannot retrieve material resource: content/levels/basic-cubemaps/reflection_probe4_bake to bind to light
Test Engine / Lua: Resource name: __level_editor_test
Test Engine / Lua: Level name: content/levels/basic
Test Engine / Lua: Warning: No shading environment set in Level, applying default
Test Engine / Lua: Loading baked_lighting for content/levels/basic.level
Test Engine / Scaleform Studio: File Not Found: FT2FontLib.json
Test Engine / Scaleform Studio: File Not Found: FontMap.json
Test Engine / Lua: Stopping test level.
3 REPLIES 3
paul.kind
2 things to try.
1. Clear the reflection probes (its a button right below bake reflection probes)
2. Delete your projects data folder and let it recompile.
If neither works, hit me back and ill look deeper.
Areas of Expertise - MayaLT : Mudbox : 3DS Max : Inventor : Game Dev
Follow me on Twitter : @paulkind3d
Please remember to give kudos freely and mark acceptable answers as solved!
PLEASE do not send me private messages unless asked to do so. If you have a question, start a thread, and ask me on the public forums where answering your question may help others.
Did you know there was a YouTube learning channel for Autodesk Games? New videos are posted regularly with all sorts of content relative to Stingray, Maya/MayaLT, 3DS Max, and other game related tools. Get your game on @ https://www.youtube.com/user/autodeskgameshowtos
in reply to: paul.kind
Seems to have worked! Cleared the probes and it seemed to have baked correctly with no errors. Thank you!
I do have one question, is there a way to stop the project loading in Free Cam mode when it's run? At the moment when I test the project, it spawns into the environment as the free roam camera which I don't want for the final release. Or is there a way to remove it completely? So when they spawn into the environment, it puts them straight in walking mode.
Hi Paul,
I've had this error but neither works for me, it works temporarily but then whenever I get 3 or more probes in it and bake then it goes back to the error.
Not sure what to do next?
Joel
