Pull object to me with laser pointer and joystick?
medmonds
Message 1 of 8
medmonds
In the Oculus Home environment from the Beta released last year, you can grab objects that are across the room (out of reach) by pointing the controller at it, pressing and holding one of the Touch controller buttons to pick it up, and simultaneously pulling back on the Touch joystick to pull it towards you.
This seems like it should be possible in Stingray with ray-casting to highlight dynamic actors.
Yes?
Any suggestions or tutorials on this type of action?
Thanks!
Replies (7)
Message 2 of 8
francis.lavergne
Yes I think it's all possible. Here's a few tutorial that can help you getting started:
Creating a laser pointer:
https://www.youtube.com/watch?v=nJggg-0Phr8
Select objects with Raycast: (the tutorial use the mouse, but you can do the same logic with the laser pointer.)
https://www.youtube.com/watch?v=h_niElj-YUU
Move the object with a jowstick: (the tutorial use a character, but it could be the selected unit)
https://www.youtube.com/watch?v=c_oyw8bRuHI
https://www.youtube.com/watch?v=EqNR0fGONSY
Also, there is a custum node in the Oculus template called "Set Unit Highlight" that you can use to highlight a unit.
Message 3 of 8
medmonds
Thank you Francis! This type of help is exactly what I needed.
Now lets see if I can connect the dots and make it work:)
Message 4 of 8
medmonds
Paul's tutorials are incredible...
Only problem is that his Lua scripts are no longer posted for download with the video. Do you have them?
Thanks.
Message 5 of 8
francis.lavergne
The files for the laser pointer ?
They should be here:
https://area.autodesk.com/tutorials/creating-a-laser-pointer-in-stingray/
Message 6 of 8
medmonds
Perfect. I was looking for them in the wrong place.
Thanks for the quick reply!
Message 7 of 8
medmonds
So I've tried to follow the same Level flow steps to make the laser pointer work for the Oculus Rift, however there are some differences in the nodes that I haven't been able to resolve. To start with, I'm not clear on the which name to use to identify the left and right controllers. Has anyone setup a laser pointer functionality for the Oculus Touch and can point out what needs to change from Paul's tutorials?
Message 8 of 8
francis.lavergne
You just need to use the Oculus Controller Pose node, and the Controller Type are TouchRight or TouchLeft.
