Get Project path
Get Project path
Get Project path
I am trying to do some lua io writing to file operations. Is there anyway I can retrieve the Project folder path?
I guess its possible since everything is relative to the project folder.
Thanks!
paul.kind
As you said everything is relative to project path. I am not sure exactly what you want to achieve since everything in your project is already known.
Areas of Expertise - MayaLT : Mudbox : 3DS Max : Inventor : Game Dev
Follow me on Twitter : @paulkind3d
Please remember to give kudos freely and mark acceptable answers as solved!
PLEASE do not send me private messages unless asked to do so. If you have a question, start a thread, and ask me on the public forums where answering your question may help others.
Did you know there was a YouTube learning channel for Autodesk Games? New videos are posted regularly with all sorts of content relative to Stingray, Maya/MayaLT, 3DS Max, and other game related tools. Get your game on @ https://www.youtube.com/user/autodeskgameshowtos
For example, I am doing some lua.io operations to create a text file in the root project directory.
file = io.open("output.txt", "w") -- This does not works
file = io.open("C:/Users/Me/Desktop/Project/output.txt", "w") -- This works
Hence, I am wondering if there are some tokens which I could use to get the project folder path.
For example something like:
file = io.open("%ProjectDIR%/output.txt", "w")
Thanks!
