Door Trigger Not Working
RichJacobUK
Message 1 of 15
RichJacobUK
Hi All,
I hope you are all well.
I am currently learning Stingray/Interactive version 2.1.777.0
I am trying to make a door open with a trigger as in this video https://www.youtube.com/watch?v=RIGf2TKVAys
My problem is that when I test the level, the trigger doesn't seem to be working at all.
In the video Maya was used to create the animated door, I am using Max 2018.
I have created a simple single door animation with an open and close and Ive added a trigger object , as in the video.
Next , using the Game Exporter , I have exported as 2 clips ( open /closed ) ... again as in the video.
I have opened Stingray and created a project using the Desktop VR template
Next I create a new empty level
Then I created a simple floor plane in Max ( collapsed to edit poly ) and using the the Stingray connection, I send selection to stingray and drag into the level.
I then use the Import function in Stingray to bring in the Door fbx animation into my content folder. All of this goes without a problem.
Still following the video , I open the door in unit editor and apply the correct settings.
I make the trigger invisible
Then set up the Unit Flow
At this point I save the level and close the Unit editor.
Next I drag my door object into the level and place it at 0,0
As far as I can tell I've followed the tutorial to the letter.
But when I test level the door animations are not trigged. I was wandering if maybe it was the template I am using. I am building the VR environments to be used with Oculus Rift.
Is there something I can look out for in the Log console that will indicate the problem ?
Could it be anything to do with how I am building the door object/trigger in max . Or in the way I export the FBX ?
Failing that can somebody please take a look at the scene for me.
Any help would be much appreciated.
Kind Regards
Replies (14)
Message 2 of 15
raiden_xavier
Autodesk Support
Autodesk Support
Hi @RichJacobUK,
Hope you are enjoying your stay in the forums.
First up please ensure you are using version 2.1 of Stingray/Interactive.
Next, check the 2 images below. Most people I have helped with this are not aware of the Character Trigger setting.
Lua example:
trig-lua
Shape template set to 'Character Trigger'. Default is typically 'Trigger'.
char-trig
That should do it. If not, please let us know.
Hope that helps.
Best regards,
Message 3 of 15
RichJacobUK
Thanks for your reply @raiden_xavier
Not sure why, but the images you included are not showing up in the post for me ??
I have managed to operate the trigger with an object that i pick up with the Oculus Touch Controllers, which is great and very useful for me , as I will be designing a door that is opened with a keycard.
But I still havent worked out how to do it with an object attached to the HMD. If I use a Character Template to begin with then it works fine, but thats due to there being a character in the template. My ideal scenario is to Use a Desktop VR template and attach an object to the HMD Pos and make it a character. Thats the understanding I have anyway 🙂
Thanks for your time and input. much appreciated.
Message 4 of 15
raiden_xavier
Autodesk Support
Autodesk Support
Hi @RichJacobUK,
I attached the images. You should be able to see them hopefully!
img: Luaimg: Luaimg: triggerimg: trigger
I think you need someone with more in-depth knowledge to chime in and help with your request however.
Perhaps @bruno.landry could point you in the right direction?
Best regards,
Message 5 of 15
bruno.landry
it's probably because your are us a VR template, I'm not sure there's a hidden character geometry in the VR template to activate the trigger (when the trigger is set to <character_character>.
Let me check if it's possible.
______________________________________
Bruno Landry
Product Manager - Autodesk 3ds Max
Message 6 of 15
RichJacobUK
Hi ,
@raiden_xavier
@bruno.landry
Thanks for your input guys.
Message 7 of 15
RichJacobUK
Hi @raiden_xavier
Quick Question.. I'm in the Level Flow console and I'm just quickly trying the setup that you posted. I cant find the "Animation Event " node like the one you used.
Is it supposed to be in the Animation menu
Is this due to the project template I am using ?
Thanks in advance .
Kind Regards
Message 8 of 15
Audio-Design
@ Bruno - I Believe your correct on this.  The HMD might have a piece of geo in it acting as the collier that may not be setup.  Check the unit of the HMD to see if it is.   Also you can try setting up the door with in a different way (push a button or collide with the controller) to help trouble shoot.
Message 9 of 15
RichJacobUK
Hi ,
@Audio-Design
Thanks for your input .
I found the HMD unit and had a look at how it was set up.. before I start messing with anything or abandoning the VR Desktop Template altogether  , I wanted to show you what I have setup at present.
It seems like its setup to be able to activate a trigger but is there something missing from this setup  ?
I am very new to Stingray/interactive 🙂
If the only way that the trigger can be activated by the HMD is to link an object to it.. would I achieve that in the HMD's Unit Flow ?
Message 10 of 15
RichJacobUK
Just to Add to my last reply above ...
Spent the day trying to understand flow nodes and although its been very useful I still haven't managed to workout how to Link my collision object to my HMD pose. I've been told this is a simple process but I'm not convinced  🙂 .I do feel im getting closer though. Im leaving the office soon so wanted to just put up here some screenshots of where I am atm .
I have an animated fbx containing a door frame, double doors and collision trigger object ( simple cube ).
Ive set up my scene in Interactive . Imported the doors FBX . Set the unit flow up , added a sphere and set it up to trigger the doors . At present in VR I have to pick up the sphere and use it to open  and close the doors .
I need to now Link the sphere to the HMD pos .. this process has been outlined to me by Shanii but ive not been able to find the information i need to do this successfully.  What I need is an illustration of the Flow nodes needed to achieve this .
Surely somebody has this setup already for the oculus template and can show me an example of the unit flow needed to achieve what I need. Thanks in advance.
Kind regards.
Message 11 of 15
ThijsSchade
Dear Rich,
Did you ever manage to attach the sphere to you HMD?
I am looking for the same info and get half hints on how to do it, as if I am stupid.
Just can't find the exact info, so I hope you have it.
Regards, Thijs
Message 12 of 15
RichJacobUK
Hi Thijs
No I haven't managed to get that to work yet. I know exactly what you mean tho. I came to the forum after exhaustively searching for the answer and trying to work it out logically . But I ended up feeling like I was given clues to the answer which is so not helpful when you are already lost. I totally appreciate people giving away their knowledge for free and its really how things progress properly. So if anyone is out there and feels ok about teaching the rest of us then I think we could progress. Other than that it seems we have to go through the same struggles over and over 🙂
I hope you find a solution . I have found a course online for 3ds Max Interactive and Im trying to convince my firm to sign me up to it. It's a 3 day course and looks very comprehensive.
Good Luck with it all. Keep me updated please.
Regards
Message 13 of 15
ThijsSchade
I have the feeling it is an interesting piece of software, but with some serious flaws.
I had a 3 day course from Autodesk, but even then there were differences in unit flow nodes betweeen the same versions software. Very weird.
I will keep searching.
Message 14 of 15
Message 15 of 15
