Android Apk file installation problem
Hi Everyone,
I have created the stingrey basic project using the basic templete.
Then i just exported to the android platform, the application was successfully complied and exported the apk file.
When i try to install the apk file in my mobile i am getting one error message called "There was a problem parsing the pacakage".
After that i cant able to install the apk file.
Please help to solve this issue.
Thanks.
Replies (10)
Hey
( I don't work for Autodesk )
Is your device compatible witht the supported Android devices?
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/ENU/Stingray-Help/stingray-hel...
dan.matlack
Hello ssivamurugan,
Could you provide some more info for us? What type of device are you trying to install on? Have you tried live linking to the device or deploying a build on it? Did that work?
______________________________________
Dan Matlack
Senior Content Manager || Games Solutions
Autodesk, Inc.
I just tried to install the app in micrax A177 device which has 1gb of ram and jelly bean os... Unused to test all my jnity Android app in that device only.
dan.matlack
Android Device Compatibility
The Stingray engine supports Android devices with Tegra K1 GPUs or Qualcomm Adreno 330, Adreno 420, and Adreno 430 GPUs, such as:
Device Name GPU
NVidia Shield Tablet Tegra K1
Samsung Galaxy Tab Pro 8 Adreno 330
Samsung Galaxy Note 4 Adreno 420
Sony Experia Z3+ Adreno 430
Important: These devices are listed as examples only. In some regions, these devices ship with different GPUs. Confirm that your target Android device uses the GPU you expect before trying to deploy your game. When you start Stingray, the device GPU brand is printed in the system log, but there are also various online resources or apps that can help you determine the GPU used in a specific device.
Dan Matlack
Autodesk, Inc.
I am having my nexus 5x mobile then why its not installing in that?
dan.matlack
Adreno 418 is not in the list of supported GPUs.
Dan Matlack
Autodesk, Inc.
So it won't run?
dan.matlack
Correct. If your device is not supported, the software will not run on it.
Dan Matlack
Autodesk, Inc.
Nexus 5x is the latest mobile I don't know about the adreno model number at all. But it should support the Android file. Any way I will check it.
oldrollapk
Community Visitor
Community Visitor
There is a problem with your package file check more on oldrollapk to install it correctly.
