you definitely have the root constained to something else.
select the root and open the selection explorer and find the constraint operators and then delete any of them. Should work.
other than that
you can view the hierachy by using the schematic view (9 key) and check the connections.
You can break constrain by selecting the green pointer/arrow ( between the driven and driver) and tap delete key.
