Softimage Forum (Read Only)
Welcome to Autodesk’s Softimage Forums. Share your knowledge, ask questions, and explore popular Softimage topics.
Autodesk Softimage 2014 SP1/2014.5/2015?- Wishlist
4 REPLIES 4
2352 Views, 4 Replies
Hi guys, i don't know where i can start this, i was looking a topic or forum for something like this, didn't find any active thread.
Anyway, assuming people still read this side of the Area. I would like to suggest people put all their wishlists for the future versions of Softimage. I have a lot, but i can't put everything here, maybe in a few posts.
-A revamped "image clip viewer" with more options(zoom,pan,rotate), better crop function, etc
-Duplicate/Instantiate, with a "preview" button. It's so hard to return everytime to the same pop-up window to make corrections and such.
-To follow the same path of all Autodesk products, please let us change the Interface Color from "Light Gray, to Dark Gray"; both are good.
-The FX-Tree needs so many improvements...
-More improvements to the HQV, all people are asking this since stone age.
..more to come.
4 REPLIES 4
-Enhancements in UV editor would also be good.
-A RULER!!! please, since pre-stone age a ruler is needed in Softimage! as simple as that!
-Locating primitives by clicking somewhere in the viewport ( no predefined primitives as well)
A good feature I'd like and found lacking and cumbersome (having to use a Texture Array Switch) The ability to not only loop and retime an image sequence clip in the animation mixer, but to repeat and instance a new sprite sequence. Example: animate the start frame offset, in order repeat the same sequence later on in the timeline.
keeping what you selected (point, edge, poly) even if you subdivid.
Le_Vikingo
As you said there are a number of things, but I would really like to see spline tools similar to what is present in 3ds Max.
