A good feature I'd like and found lacking and cumbersome (having to use a Texture Array Switch) The ability to not only loop and retime an image sequence clip in the animation mixer, but to repeat and instance a new sprite sequence. Example: animate the start frame offset, in order repeat the same sequence later on in the timeline.
