Hello. I used to be able to open Sketchbook (for Mac) on my Cintiq after working with it. Now It will only open on my main computer monitor and have to drag the workspace to the Cintiq every time! It's very frustrating and wastes time I need to work. What has changed since it used to work is this...I had to downgrade my Mac OS since the new upgrade has made my old Cintiq useless. However I don't see why Sketchbook wont open on the Cintiq like it used to, it's been able to do this for 3 OS's. P.S. I am currently aback to High Sierra.
Thanks!
Solved by dragonbrushstudio. Go to Solution.
What is the exact model of your Cintiq and what driver are you using?
I would go here: https://www.wacom.com/en-us/support/product-support/drivers
Then click on Older Versions and try an older version of the driver. If you plan to go back to Mojave, I would use this one: Driver 6.3.31-3.
But because you already spent time downgrading back to High Sierra, please stay on that OS so I can test it out a bit more. i.e. I need to know your model of Wacom tablet.
Map Express key to [ & ] : See: https://www.youtube.com/watch?v=Pk7h8bA2ozw
Under Preferences are the Hotkey Shortcuts.
IMHO, once you are setup on the Cintiq, I wouldn't change a thing because you are running an older tablet.
