SketchBook Forum
Hello Sketchbook Community Members! Sketchbook started a new exciting endeavor. This forum is now read-only mode. Please visit the new Sketchbook Help Center, https://help.sketchbook.com/ in the future. Happy sketching!
Sketchbook for Windows 10 keeps opening in Chinese (Instead of English)
3 REPLIES 3
543 Views, 3 Replies
Have tried re-downloading several times but the issue still persists.
Others on this forum have had this issue resolved but I don't seem to be able to access the solution.
3 REPLIES 3
Hope attachment IMAGE helps.
If a clean install does not work -
You will have to navigate through the menu as is -
>Edit (the second option at top) - there should be an E -
>Preferences (at the very bottom)
>Language will be obvious (as even though Chinese is the language in use English is used to refer to it)
So as to reduce the odds of it changing back --- be sure layers are listed in English ONLY 'Layer #'
If any layer is listed in Chinese it may eventually overwrite preferred setting.
got that ! Thankyou!
That seems to have worked! I didn’t see your attachment before. Thankyou!
