SketchBook Forum
Hello Sketchbook Community Members! Sketchbook started a new exciting endeavor. This forum is now read-only mode. Please visit the new Sketchbook Help Center, https://help.sketchbook.com/ in the future. Happy sketching!
Scanned image with resolutio 300 DPI
4 REPLIES 4
564 Views, 4 Replies
Hi everybody and thanks for your time.
I want to import my scanned drawings in Sketchbook Pro to add digital details, but when I import the scanned 300 DPI image the result is the one below. Ia also attach the original drawing for confrontation. Does anybody know how to avoid this issue?
4 REPLIES 4
david.lau
What are you using to 'scan' the image?  Are you using the Scan Sketch Option in the mobile app?
http://help.autodesk.com/view/SKETPRO/ENU/?guid=SKETPRO_Help_sb_tools_how_to_scan_sketches_html
David Lau
in reply to: david.lau
No David, I have scanned the image on an external scanner
I forgot to mention that I'm using a Sketchbook desktop version on my PC. I have Sketchbook app also on my iPad but I'm not sure it does manage 300 DPI images, does it?
david.lau
If you have manually scanned the image, I would create a new canvas with the correct size and at 300 DPI.    The mobile version does not support 72 DPI, you can use a higher resolution and down size it from there.
Mobile Canvas Size (72 dpi upscaling resolution)
https://www.scantips.com/calc.html
Canvas Size Resolution TIP
https://blogs.autodesk.com/sketchbookpro/trents-tips-what-resolution-should-you-use-anyway/
David Lau
