I am unable to install Autodesk sketchbook pro in my new Huawei matebook E 2019
Which is having Processor: Qualcomm snapdragon 850.
OS: Windows 10 pro
Is there any procedure to install it.
Please suggest,
I bought the product to use Autodesk sketchbook.
Solved by david.lau. Go to Solution.
Can you send me a screen capture of the error when trying to install it?
If the device is only 32 bit, try this:
32 bit - 8.5.x version:
You can also try this 64 bit version - 8.6.x.:
If you are installing from the Microsoft Store, the app may only install on Intel devices.
Can I ask how the 32 bit version is working on your snapdragon PC? Is it smooth or does it lag with the pen?
thanks~!
