You can save the file in .tif format. Just plug it into a computer and navigate to the /Autodesk folder
https://www.sketchbook.com/help/knowledge-base/back-files-settings/
If you need it layers exported out, you need to export to .psd and email off your device. Then Photoshop will be able open file with layers. If you open the SketchBook .tif file, the layers will be flattened.
If you are on 3.x (Pencil logo), just test it out.
1. Create a scribble.
2. Add a layer, scribble.
3. Add a layer, scribble.
Start new sketch, Save. You can sketch again, start new sketch and save.
Then open Gallery and confirm that "the previous' sketch had 2 layers. (sribble/layer).
1. Confirm that you are in Pro mode in SketchBook (mobile version). To confirm that you are in Pro mode, when you click on the Pencil/Ruler icon, it should have 9 tools in it.
2. The larger the canvas, the fewer the layers. This is to improve the performance of the product and to address 'power' of the CPU & Graphics across the many mobile devices on the market.
iPad Pro 12.9 - 2732 x 2048 - 18 layers
iPad Pro 9.7 - 2048 x 1536 - 12 layers
Note 4 Edge (SM-915C) - 800 x 1280 - 18 layers
Galaxy Note 10.1 (SM-P600) - 1280 x 800 - 18 layers
https://www.sketchbook.com/help/knowledge-base/sketchbook-mobile-maximum-layers-canvas-size/
3. The maximum resolution of SketchBook on mobile is 72 DPI. This means you need to sketch using the largest size possible and then scale it to to increase the DPI of the SketchBook before printing it.
https://www.sketchbook.com/help/knowledge-base/setting-maximum-canvas-size-printing-different-versio...
