SketchBook Forum
Hello Sketchbook Community Members! Sketchbook started a new exciting endeavor. This forum is now read-only mode. Please visit the new Sketchbook Help Center, https://help.sketchbook.com/ in the future. Happy sketching!
Pen sensitivity not working properly
25 REPLIES 25
Message 1 of 26
45291 Views, 25 Replies
Whenever I open Sketchbook and start drawing, the brush acts like I'm using full pressure with my pen when I'm not and I don't know how to fix it. Help!
I use a Windows HP Pavillion Sleekbook 15.
25 REPLIES 25
Message 2 of 26
Have you gone to " preferences " to see if you can set your options from there , or try factory default also found in preferences and reset it from there. See if that helps.
Message 3 of 26
I just did, nothing changed though. Thanks anyway.
Message 4 of 26
patrick.muenster
I got this issues sometimes with my Wacom tablets. This failure is caused of a service for pen input that influences your default input. Maybe there are some other services running?
For me, I've found the following three services and one options that have made problems sometimes:
  • TabletInputService
  • Pen_Tablet.exe
  • Wacom Consumer Service (only for Wacom user)
  • Windows Freehand option (option only for Wacom user)
You can try to end them and see what's happening. You can't do anything wrong by trying.
Message 5 of 26
in reply to: patrick.muenster
I had also replied to this issue , but it wasn't me with the issue. It was jogo257
Message 6 of 26
Forgot to add that I use a Wacom Cintiq 13HD
Message 7 of 26
patrick.muenster
If your using a Wacom Cintiq, then please try the marked option in the image.
I'm sorry, but I don't know how it is called in English. You can find this option in your extended pen settings.
It worked in Sketchbook with my Cintiq 21UX.
Message 8 of 26
Message 9 of 26
patrick.muenster
The settings should be under "options..." or "calibrate".
I currently have no Cintiq connected to my PC. Maybe I can send you an image from my Cintiq settings later.
Message 10 of 26
- the Cintiq 13HD I mean.
Message 11 of 26
That would help. Thanks
Message 12 of 26
patrick.muenster
So now I got a picture from my Cintiq Companion setting.
You can find the windows freehand under the calibrate tab at the bottom.
Try to activate or deactivate this option. Maybe you have to restart Sketchbook to see the effect. At my device pressure sensitivity is been deactivated immediately.
Message 13 of 26
It worked! Thank you!
Message 14 of 26
That's terrific !
Message 15 of 26
patrick.muenster
You are welcome! 🙂
Just for my personal information: Would you please tell me how this option is called in the English version?
Message 16 of 26
What would be Windows Freehand on your system, it's called Windows Ink on mine.
Message 17 of 26
I have a Trust Flex tablet, and what fixed the issue for me was enabling the "Support Tablet PC Feature" option.
Message 18 of 26
Try to activate or deactivate " windows ink " option. pen tilt and pressure is control by this option .
I have a xp-pen artist 15.6 pro display monitor tablet . 1920x1080 resolution of 15.6 inch ips screen , 88 percent NTSC color gamut . 8 hotkeys and 1 red roller wheel . the stylus has 8192 pen pressure levels and support pen tilt function . the stylus is battery-free and wireless , I can't find any flaw, tracking is accurate and the screen is great. The only thing it doesn't have is touch .
Message 19 of 26
Hi, my pressure sensitivity works perfectly in Photoshop but not with the Autodesk SketchBookPro. I have Wacom Intuos Pro M, Win 10. Anyone help please
Message 20 of 26
Same here... My Pressure sensitivity only works with Photoshop, but not Sketchbook Pro 2020
Same problem with my Surface Book 2 and Desktop with (Cintiq 24)
P.S
I tried with Windows Ink (activate and deactivate) , didnt work, unfortunately... Please help 😞
