My ToolBar is Missing
Message 1 of 14
I just began sketchbook on a premium subscription. A little while ago my toolbar disappeared, however, i did move some things, but not the toolbar.
I am using the Newest Version of sketchbook and I have a MacBook Air 2016.
Replies (13)
Message 2 of 14
david.lau
Toggle the title bar to be on via the Lagoon.
http://autode.sk/2nwn2QL
David Lau
Message 3 of 14
My toolbar is missing also, but I can't use this solution because the lagoon is ALSO missing... 😞
Message 4 of 14
david.lau
Please use this version of SketchBook.
Desktop (Full Featured)
www.sketchbook.com/thankyou
UWP (Windows 10 store) - best for tablets - higher UI - No tool bar or Lagoon
www.sketchbookk.com/windows10 - blue button
David Lau
Message 5 of 14
The best way to do this is to completely quit out of autodesk, when it is removed from your hot-bar, then re-open it in the launch pad.
Message 6 of 14
david.lau
If you are on Windows 10 (Download: www.sketchbook.com/windows10), it is here:
If you are on the Desktop version of SketchBook (www.sketchbook.com/thankyou), you can show/hide UI elements via the Lagoon.
David Lau
Message 7 of 14
that link doesn't work
Message 8 of 14
Go to the Window tab at the top left hand corner of the screen, and select default layer. I had the same problem and I just figured it out!!
Message 9 of 14
My TollBar is missing. I tried to activate it from the lagoon and I don't want to disinstall it because I'm afraid to lose my drawings. Please someone help me!!!!
P.S. I'm on IOS.
Message 10 of 14
david.lau
iOS version is different form the desktop version.  The iOS/Android version is using a touch capable UI and uses a smaller real estate for UI (lighter than desktop).  The desktop version is also free.
David Lau
Message 11 of 14
No sorry I meant “I’m on Mac”
Again, sorry.
Message 12 of 14
david.lau
@Anonymous
I would watch this video:  http://autode.sk/2nwn2QL
There are some UI elements you can hide via the Lagoon.
You can also move your cursor to the top of the screen to bring down the title bar that has the red/amber/green buttons to bring back SketchBook from full screen mode.
David Lau
Message 13 of 14
Thank you so much!
Message 14 of 14
tysm
