I'm on a 8th gen Levono 920 with a Pro student sub for Sketchbook.
I can't customize my lagoons. Whenever I click on the bottom tab to change a option on the wheel- the bluelight grays out. I'm able to change the initial center top option as normal, but only that one; and only until I try to click on another option on the wheel.
I can change the icons for the categories on the top as normal. Only the bottom tab is giving me issues.
I've done every combination of Factory reset and Uninstall/reinstall already and nothing.
@david.lau what high DPI scaling settings should I use on a Surface Book 2 running latest version of SketchBook?
If I use the default scaling settings (by Application) I cannot edit the lagoon preferences. I have the same issue noted previously where the Reset, Ok, Cancel buttons display as very large.
If I change to scaling by System I can then edit the lagoon preferences but the UI becomes very pixelated / blurry.
