How to move a selection to another layer?
I’ve started drawing multiple objects on one layer, and would like to seperate them into their own individual layers. I can seem to figure out how to do that, I can make a selection and move it around but cannot add it to another layer.
Is it possible to do? Please help!
(I am using Sketchbook free on iPad)
david.lau
Cut/Copy/Paste into a new layer.  The Cut/Copy/Paste Function is in the Layer Editor - it flies out when you click and hold on the layer you are currently active in.
David Lau
I'm not seeing the cut and paste option when I hold on the layer I'm working on. When I select the content, I can use ctrl+copy and then ctrl+paste onto the new layer, but then it deletes everything else. Ideas?
david.lau
You may need to use a selection tool (in the layer that you are going to cut) and then copy it into a new layer.
David Lau
