SketchBook Forum
Hello Sketchbook Community Members! Sketchbook started a new exciting endeavor. This forum is now read-only mode. Please visit the new Sketchbook Help Center, https://help.sketchbook.com/ in the future. Happy sketching!
Deadlines Approaching
1 REPLY 1
365 Views, 1 Reply
Sketchbook isn't just a little kids drawing app. Some of us depend on this for business. Where are you at with a fix on the latest Android update? Can you just "restore previous version?" Help!
1 REPLY 1
david.lau
If you need an older version, you can get it from apkmirror.  Although it is note supported, you an give it a try:
https://www.apkmirror.com/apk/sketchbook/sketchbook-draw-and-paint/
Download .apk and then click to open it and it will ask you to install it.
I would submit your issue here with exact step by step to reproduce the issue if you are experiencing crashes.
Scroll to bottom > Submit a topic.
NOTE:
https://forums.autodesk.com/t5/sketchbook-forum/heads-up-this-forum-will-change-to-read-only-mode/td...
https://forums.autodesk.com/t5/sketchbook-forum/the-future-of-sketchbook/td-p/10411917
https://forums.autodesk.com/t5/sketchbook-forum/android-sketchbook-tips-and-tricks/td-p/9385407
David Lau
Technology Administrators
