SketchBook Forum
Hello Sketchbook Community Members! Sketchbook started a new exciting endeavor. This forum is now read-only mode. Please visit the new Sketchbook Help Center, https://help.sketchbook.com/ in the future. Happy sketching!
brush palette missing
15 REPLIES 15
Message 1 of 16
10282 Views, 15 Replies
the brush palette (even though it's checked) isn't visible.
If it helps, I use a MacBook Air macOS Sierra Version 10.12.6.
SketchBook Pro Subscription Version 8.5.1.
I use a Wacom Bamboo tablet CTL-470
(I've never posted anything to the forums before so sorry if I'm posting this in the wrong place)
15 REPLIES 15
Message 2 of 16
david.lau
Try this:
http://autode.sk/2nwn2QL
David Lau
Message 3 of 16
in reply to: david.lau
Sorry, it didn't work.
Message 4 of 16
david.lau
SketchBook > Preferences > Factory Defaults -> Reset 3 sections.
If that doesn't help, please send me a screen capture of the issue.
David Lau
Message 5 of 16
It worked! Thank you so much!
Message 6 of 16
Thanks so much, that worked!
Message 7 of 16
My brush palette has come back and gone missing over and over. I tried the link from the Top Answer of this forum, but "Page Not Found".
Message 8 of 16
Mine is missing.
Message 9 of 16
@Anonymous @Anonymous
I had to do the second option @david.lau listed-
sketchbook > preferences > factory defaults
Reset brush palette and library is what you want to reset, but if that doesn't fix it then I guess reset all three.
You'll lose any settings you had on brushes so I recommend saving any settings you want by making custom brushes. you can do this by selecting the brush you want and double-clicking it to open the settings for the brush, then clicking export.
hope this is helpful :).
Message 10 of 16
Appreciate it!
Message 11 of 16
david.lau
90% of the time....Window > Default Layout will also work....
David Lau
Message 12 of 16
It worked! Thank you😃
Message 13 of 16
Good afternoon,
So I have been using sketchbook for a while now, and for some reason, the toolbar and brush palette have gone missing, I have tried to press every single button the application and none of them made my palette nor my toolbar appear again, what should I do? I have seen where you say to go to Sketchbook > Windows  but I can't seem to find a way to go there. Also, I am using MacOS 11.0.1
Thanks, Elvis
Message 14 of 16
david.lau
@Anonymous   You have used the lagoon to go to full screen mode.  Try this:
https://autode.sk/3earPj8
David Lau
Message 15 of 16
@david.lau I had followed the instructions of utilizing the Lagoon on the video, but my toolbar & Palette are still unavailable. I had even tried to open the palette again in the lagoon brush area after following the instructions, but they are just no appearing for me. I have also left full screen from the lagoon, and on my mac.
Message 16 of 16
a few of my things are missing and I've tried doing what its said on this thread but things haven't been working. I've also tried deleting and redownloading the program that didn't hep with the issue either2021-02-09.png
Technology Administrators
