the brush palette (even though it's checked) isn't visible.
If it helps, I use a MacBook Air macOS Sierra Version 10.12.6.
SketchBook Pro Subscription Version 8.5.1.
I use a Wacom Bamboo tablet CTL-470
(I've never posted anything to the forums before so sorry if I'm posting this in the wrong place)
Solved by david.lau. Go to Solution.
SketchBook > Preferences > Factory Defaults -> Reset 3 sections.
If that doesn't help, please send me a screen capture of the issue.
My brush palette has come back and gone missing over and over. I tried the link from the Top Answer of this forum, but "Page Not Found".
@Anonymous @Anonymous
I had to do the second option @david.lau listed-
sketchbook > preferences > factory defaults
Reset brush palette and library is what you want to reset, but if that doesn't fix it then I guess reset all three.
You'll lose any settings you had on brushes so I recommend saving any settings you want by making custom brushes. you can do this by selecting the brush you want and double-clicking it to open the settings for the brush, then clicking export.
hope this is helpful :).
Good afternoon,
So I have been using sketchbook for a while now, and for some reason, the toolbar and brush palette have gone missing, I have tried to press every single button the application and none of them made my palette nor my toolbar appear again, what should I do? I have seen where you say to go to Sketchbook > Windows but I can't seem to find a way to go there. Also, I am using MacOS 11.0.1
Thanks, Elvis
@Anonymous You have used the lagoon to go to full screen mode. Try this:
@david.lau I had followed the instructions of utilizing the Lagoon on the video, but my toolbar & Palette are still unavailable. I had even tried to open the palette again in the lagoon brush area after following the instructions, but they are just no appearing for me. I have also left full screen from the lagoon, and on my mac.
a few of my things are missing and I've tried doing what its said on this thread but things haven't been working. I've also tried deleting and redownloading the program that didn't hep with the issue either
