Hello digital artists i wanna know what is the best resolution should i use for cartoons/characters , without getting these blurry lines when i zoom in. thanks ! .
Solved by david.lau. Go to Solution.
On Mac or Windows, I would start at 300 PPI/DPI.
https://blogs.autodesk.com/sketchbookpro/trents-tips-what-resolution-should-you-use-anyway/
If you are on iOS/Android, you can figure out the resolution via:
https://www.scantips.com/calc.html
iOS/Android can only input page/canvas size via 'pixels'.
