Account problem
Account problem
Message 1 of 9
Account problem
Well basically the problem is that i signed in on sketchbook but every time i open it the"create an account or sign in" box keeps popping up.
And also when i sign in with my account on another decice i can't seem to find any of my other drawings
Replies (8)
Message 2 of 9
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Sketchbook is not supported here.  It has its own community/support.  Please post over there.   But I will have the moderator relocate your posting there to best suit your needs.
Mark Lancaster
Message 3 of 9
Im confused. The link that you sent me was the same page where i wrote my help request previously
Message 4 of 9
Mark.Lancaster
@Anonymous
Well your posting is in the installation and licensing forum.  Perhaps someone had moved it here before I saw it.
Mark Lancaster
Message 5 of 9
Oh. So does it mean i should repost the help request on the link you sent me or is it alright now?
Message 6 of 9
Mark.Lancaster
@Anonymous
I requested your posting to be moved over to the Sketchbook forum but its still here..   You can wait or post a new one over there and link it back to this one.
Mark Lancaster
Message 7 of 9
natasha.l
Hello @Anonymous,
Thank you for posting. I moved your post over to the proper forum to see if a Sketchbook expert can assist with this issue as well. If you have created a Sketchbook account & continuously receive the sign-in dialog window please follow the steps below:
  1. Close all Autodesk programs. Make sure Autodesk Desktop App is closed from the task bar in Windows.
  2. Navigate to C:\Users\%username%\AppData\Local\Autodesk\Web Services.
  3. Make sure that the file LoginState.xml is not set in Read only mode (Right-click > Properties).
  4. Open the Autodesk Autodesk Desktop App and Sign in.
  5. Open the Autodesk Software.
If the issue persists, follow the steps below:
  1. How to change or reset licensing for Autodesk software
  2. Reset your Autodesk account password.
  3. Launch the Autodesk product. If asked, Sign In with your Autodesk credentials.
  4. Install the lest update of AutoCAD.
Please note that network securities can affect the the performance of software temporarily disable or make exceptions to security settings like Antivirus, Firewall & UAC on your Windows operating system if this issue persists.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 8 of 9
Thank you for the help but now i realize i forgot to mention that im using an iPad to draw. Someone once suggested that i delete and redownload the app but i wouldn't want to lose all my previous artworks
Message 9 of 9
david.lau
If you delete the app, you will indeed delete all your sketches.  If there are no sketches in the Gallery, you don't have any sketches in SketchBook.  I am sorry to tell you that.  I would start saving your sketches to the iCloud.
http://help.autodesk.com/view/SKETPRO/ENU/?guid=SKETPRO_Help_sb_file_saving_use_icloud_html
David Lau
