The Simulation Mechanical Idea Board has been closed down and placed in read-only mode following a recent discontinuation announcement. Please see our supporting FAQ for more information.
max by part
max by part
Hi
A new feature has been implemented in release 14, ie maximum value by ; i think knowing where this maximum is occuring should also be very interesting to know.
4 Comments
Sualp.Ozel
Status changed to: Comments Requested
HI Alain, Can you please elaborate on this enhancement request. what specifically are you asking for here ? Do you want to see the X,Y,Z coordinates of the maximum and the minimum point in the dialog? -Sualp
Sualp.Ozel
Status changed to: Accepted
Summary of the improvement request: As a user, I want to see the X,Y,Z coordinates of the maximum and the minimum results per part in the "Inquire:Results by part" dialog.
Perhaps this idea can also be applied as an optional way to display the Max & Min probes in the results environment?  On a large assembly, it would be helpful to see each parts Max & Min probes graphically (in addition to the XYZ coordinates listed in "Results By Part" dialog).
Sualp.Ozel
implemented in the 2016 release
Technology Administrators
