The Simulation Mechanical Idea Board has been closed down and placed in read-only mode following a recent discontinuation announcement. Please see our supporting FAQ for more information.
Show only
Search instead for
A new feature has been implemented in release 14, ie maximum value by ; i think knowing where this maximum is occuring should also be very interesting to know.
HI Alain,
Can you please elaborate on this enhancement request.
what specifically are you asking for here ?
Do you want to see the X,Y,Z coordinates of the maximum and the minimum point in the dialog?
-Sualp
Summary of the improvement request: As a user, I want to see the X,Y,Z coordinates of the maximum and the minimum results per part in the "Inquire:Results by part" dialog.
Perhaps this idea can also be applied as an optional way to display the Max & Min probes in the results environment? On a large assembly, it would be helpful to see each parts Max & Min probes graphically (in addition to the XYZ coordinates listed in "Results By Part" dialog).
