Variable Cross-Section Wizard with user defined shape
M.Douw9008
M.Douw9008
Hello all,
I found a prblem with the  " Variable Cross-Section Wizard " which I want to use with a user defined shape, in this case a T-profile.
First, I found out, that the only way to be able to type user defined values in this window, is to previously select the user defined option (instead of round, pipe, rectangular, etc) and fill in some values. Otherwise you can only select these standard shapes ( round, pipe, rectangular, etc) and NOT the user-defined one.
After typing the values for the sections at "A" and "B" the wizards seems to work and calculating the different values for the different layers it creates....
but if I look then in the element defintion tab, I see the layers the wizard created, but all values are the default values of the software... see attached image.
Note: I made sure that no dimension had the value 0.
Has anyone a solution for this?
Thanks in advance!
Note: I am using Simulation Mechnical 2017 on Win 10 pro.
Kind regards,
John_Holtz
Autodesk Support
Autodesk Support
Hi @M.Douw9008
The solution is to calculate the values that you need and enter them for the 4 layers (or however many layers you will have in the final model. The wizard is only designed to work with the pre-defined shapes.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
M.Douw9008
Thank you John,
i hoped the wizard would work for user-defined shapes as well. But it doesn't.
I will do it manually as you suggested.
Thanks again for your quick answer.
Kind regards, Marco
