02:20 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi!
Im trying to do a two step thermal stress analysis, im using the analysis type 'non-linear static' and im applying a 'body temperature' of 370K in 'subcase 1'. Assigning expansion parameters (on material card) to only one section part of the bolt (and also only in one direction) should cause thermal expansion and thus thermal stress. In 'subcase 2' im applying the same 'body temperature' as in 'subcase 1' and in addition a pressure load.
The 'body temperature' should work as a preload, however the registered forces from the preload does not match the expected preload using F/A=alpha*deltaT*E.
Ideas? (The reference temperature is set to 293,15K on material card)
