Simulation Mechanical
I am trying to mesh a 2D axisymmetric threaded connection in simulation mechanical. It has some interference at what would be a seal, so I have been trying to use the shrink fit/ sliding contact. The only mech type to actually mesh has been plate, but it changes the model from 2D axisymmetric to plate and does not run. How should I set this up to get it to mesh? I have also tried without the interference, and it still would only mesh in plate and does not run.
John_Holtz
Autodesk Support
Autodesk Support
Hi Matthew,
I am not clear how you are creating the mesh (using the 2D mesher on a sketch? Using the 3D mesher on a flat surface?), but my guess is that your mesh is not in the proper plane. 2D elements must be created in the YZ plane with all X coordinates equal to 0. For axisymmetric 2D elements, the Z axis is the centerline.
If this isn't the solution, feel free to create an archive of the model and attach it to a reply. See "Create, Post, or Provide an Archive of your model".
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
