Simulation Issues
Simulation Issues
Simulation Issues
After successfully meshing the 4 part model I've attempted to run simulation. I see some action in the solve log, but then the process stops abruptly after roughly 2 seconds. I've applied the loads and constraints and have even added refinement points in the more detailed areas. Just wanted to get some idea of what I could be doing wrong?
Thank you much ,
BenCOVER.jpgcloseup of perforationscloseup of perforationscontact between partscontact between parts
John_Holtz
Autodesk Support
Autodesk Support
FYI. Ben created a Schedule a Call, and I spoke to him regarding his model. We did not investigate why the analysis was not running because we uncovered other issues with the modeling. Once we fixed those issues, the analysis should have ran. (A different version of the model was running with similar changes, so I am confident that the changes he and I discussed will also work.)
If that is not the case, I am sure that @Anonymous will post an update, and we will tackle the next step. Smiley Happy
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
