Quasistatic Analysis
eugene.kluev
eugene.kluev
Hi, I want to ask your help for solving a quasistatic model.
I need to make impact analysis of glass bottle and steel ball, but I think, that it's not nessesary to make it as nolinear contact analysis. I'd tried to load the nodal force, which is active for very small period of time, but the solver stopped with the error: ** Stop: Reached autotm limit.
** Error (1).
So I ask for help in correct parametrs for such type of analysis.
If you are running an MES analysis (it might work with other analysis types, too), one likely solution is to run the analysis through a command prompt window.  I was having the same problem about a month ago, and this fixed it:
https://youtu.be/6q47HQNfYyw
