0x138F Load case or time step does not exist or the results have not yet been...
I made a simulation in - MES with nonlinear Material Model -
After I computed all the results I ran a Fatigue analysis. At the end of the analysis I see the result in an overview and close the window.
When I want to plot the result in the modul I get a failure: 0x138F Load case or time step does not exist or the results have not yet been computed
Why i get this failure and how can i solve this problem?
AstroJohnPE
I believe you need to look at time step 0 or time step 1 to see the fatigue results.
Indeed when I switch to time step 1 it worked immediately thank you very much for the quick answer and solution.
