Hi Alain,
Thanks for the clarification. The question is different than I thought.
The answer is no: Simulation Mechanical does not have that type of capability.
The key paragraph from the Freelem website is as follows:
- This method has one disadvantage: it requires the extraction of all the modes, which can prove to be long. We prefer to use the pseudo-mode technique corresponding to all frequencies higher than the cutoff frequency of the ZPA spectrum (more dynamic amplification in this frequency range).
The page goes on to describe how to calculate the response due to frequencies above the range of the spectrum (and frequencies not included in the modal analysis, if I understand it correctly.)
It would be interesting to know how much of an affect those pseudo-modes have on the result, versus the frequency. For example, a natural frequency that is X times higher than the response spectrum adds a% to the stress, a frequency Y times higher than the response spectrum adds b% to the stress, and so on. As the frequency gets higher (X to Y to Z to ...), the contribution gets lower (a% to b% to ....).
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
