Hi Autodesk Family,
My name is Fernando Zuñiga, i have some problems , i just bought a new laptop and download mecanical simulation, because in my office work with Autodesk Simulation Multiphysicis 2013.
the thing is, when i try to open a Solid Works file, the sofware show me a grong massage, i like to somebody help me to fix it. because is really important to me, my work depend on it
thanks a lot.
Solved by Sualp.Ozel. Go to Solution.
What is the exact version of Solidworks you used to create the CAD file?
Autodesk Simulation Multiphysics 2013 is a 3 year old software by now. It can not open SWX files created past a certain point in time 🙂
Please refer to the help document for its limits wrt opening SWX file versions.
As a work around, you can export your CAD files as "*.step" and open the STEP file in your Autodesk Simulation Multiphysics 2013.
Hi Sualp, the thing is, in my job work with SolidWorks (2012-2013), and in my home i work with Solid Works (2014-2015).
so just tell me please what i have to do....because when i try to open a SW file, it show me, like it just i start to install the software for the first time (look the file attached).
Hi, sualp, i send you the S.W. file, i wanna tell you something about it, when i try to open in multiphysics environment the file works, the problem is when i try to poen the file in Simulation Mechanical.
the name of the file is (ensamblaje 3), i couldn´t open it in S.M. 2015, i thought the file was wrong so i try to open sometring less complex so i draw a bolt, but without success.
i dont´n know what i have to do??
thank you for your support.
Hi Sualp i´m still waiting for your answer and i´m expecting to hear good news. please give me a hand.
