problems with mecanical simulation
Hi Autodesk Family,
My name is Fernando Zuñiga,  i have some problems , i just bought a new laptop and download mecanical simulation,  because  in my office work with Autodesk Simulation Multiphysicis 2013.
the thing is,  when i try to open a Solid Works file,  the sofware show me a  grong massage,  i like to somebody help me to fix it. because is really important  to me, my work depend on it
thanks a lot.
Sualp.Ozel
What is the exact version of Solidworks you used to create the CAD file?
Autodesk Simulation Multiphysics 2013 is a 3 year old software by now. It can not open SWX files created past a certain point in time 🙂
Please refer to the help document for its limits wrt opening SWX file versions.
As a work around, you can export your CAD files as "*.step" and open the STEP file in your Autodesk Simulation Multiphysics 2013.
Sualp Ozel, PE
Principal Product Manager
Hi Sualp, the thing is, in my job work with SolidWorks (2012-2013),  and in my home i work with  Solid Works (2014-2015).
so just tell me please what i have to do....because when i try to open a SW file, it show me, like it just i start to install the software for the first time       (look the file attached).
Sualp.Ozel
Can you e-mail me the SWX file
I will test using Simulation Mechanical 2016.
If it works, I will recommend that you upgrade to SimMech 2016 🙂
Best Regards
Sualp Ozel, PE
Product Manager
Digital Simulation
Direct: 412.455.7795
Mobile: 412.334.2555
e-mail: sualp.ozel@autodesk.com
Sualp Ozel, PE
Hi, sualp, i send you the S.W. file, i wanna tell you something about it, when i try to open in multiphysics environment the file works, the problem is when i try to poen the file in Simulation Mechanical.
the name of the file is (ensamblaje 3), i couldn´t  open  it in S.M. 2015,  i thought  the file was wrong so i try to open sometring less complex so i draw a bolt, but without success.
i dont´n know what i have to do??
thank you for your support.
Hi Sualp i´m still waiting for your answer and i´m expecting to hear good news. please give me a hand.
Sualp.Ozel
I can perform a "File: Open" and open this SWX file using Autodesk Simulation Mechanical 2016 and mesh it without any issues
I recommend that you upgrade to Autodesk Simulation Mechanical 2016
(Please see attached image for the resulting mesh)
Best Regards
Sualp Ozel, PE
Product Manager
Digital Simulation
Sualp Ozel, PE
