Node Mapping Utility
Good Morning,
I am trying to map thermal data from CFD 2016 into Simulation Mechanical 2015.  Every time I try to 'check the model', the node mapping utility consistently fails.  I have renamed both files (CFD and mechanical) to have not punctuation.  I can't think of what else to try because as you can see, the software gives me no hints as to why it is failing.  Has anyone seen this before?
Thanks for any feedback you can have
Sorry, just realize the name again messed up.  Here is instead the typical error I get, along with the file
