How to run Check Model from batch file?
Hi, please tell me with what function run the Check Model (feature under Analysis tab) from the Batch File level? For 2015 version.
Andrew.Sartorelli
To my understanding, the check model button runs a number of different processes depending on analysis type. It is not possible to run check model from a batch file.
Andrew
Andrew Sartorelli - Autodesk GmbH
Thanks for prompt answer.
How about running Solid Meshing?
Or if that is also not possible, please tell me if I am running ssap0 command, then will software make solid meshing (in opposit to surface meshing prepared earlier) before solving results?
Andrew.Sartorelli
A model needs to be checked before you can run one of the solvers regardless of if there is a solid mesh or not. A solver will not run the solid meshing routine.
Andrew
AstroJohnPE
Hi Mickey,
The thread "Run simulation from Command line" includes some command line commands for solid meshing and performing the analysis (which includes doing the "Check Model").
